Forums >> Revit Building >> Technical Support >> Undo/Redo command stops working
Thu, Nov 12, 2009 at 10:40:47 AM | Undo/Redo command stops working
trialbyfire
Hi all -
Frequently while working in Structure 09,  the undo and redo command will suddenly no longer be available.  Once that happens, they don't return until I close and reopen the file.  I don't know exactly when they quit working since I only notice when I need them (which is nice and frustrating).
Any idea what's causing this to happen?
Thu, Nov 12, 2009 at 10:58:26 AM | Undo/Redo command stops working
There are certain major commands you do that reset the undo/redo.  For instance - save to central.  I can't immediately indentify the others.  But - from the help
Note The Redo tool is available only after you use the Undo tool.
Thu, Nov 12, 2009 at 11:13:29 AM | Undo/Redo command stops working
trialbyfire
Resetting is understandable after a save, etc.  But then I'll move a line, adjust a wall, or any slew of other commands, and undo ability never returns.  It doesn't happen all the time...maybe I just have a funky project file or something.  I'm still pretty green with Revit, so me and the undo command are very good friends....and it's frustrating when your friends flake on you!
Fri, Apr 30, 2010 at 10:16:02 AM | Undo/Redo command stops working
structuresguy
DId you ever figure out what was happening?  We have we one guy here who is having exact same problem in Revit Structure 2010.   Unde/redo are not available (greyed out) no matter what he does.  Draw a line, move something, etc.  Nope, no undo.  CTRL-Z doesn't work either.  So somehow the undo function seems to be disabled.
Fri, Apr 30, 2010 at 10:33:35 AM | Undo/Redo command stops working
trialbyfire
No, I didn't.  The problem just kind of 'went away'.  Maybe it was just that particular file I was working on.
Cant Undo or Redo Because Elements are not Editable = Very Bad Revit
Wed, Apr 15, 2015 at 5:41:08 PM
How do I undo a split surface of my topo?
Thu, Oct 8, 2015 at 6:53:44 AM
RAC2009 - Kwyboard stops working after using Pantone colors
Tue, Jul 15, 2008 at 1:32:21 PM
13
Far Clipping Stops working when I zoom in/ out of view
Wed, Jul 16, 2014 at 11:20:39 AM
11
REPEAT COMMAND?
Fri, Oct 31, 2008 at 10:01:42 AM
Page generation time: 0.4413
