Forums >> Revit Building >> Technical Support >> Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
Thu, Nov 12, 2009 at 4:19:24 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
JohanEkstrom
Is there a way to control/arrange the order of the models in modelspace when I export multiple viewports on a sheet to Autocad?
They seem to be placed at random in modelspace which kinda mess upp my def:s in AutoCad...
The example contains a sheet export with the viewports placed correctly in paperspace, left to right, but in modelspace they are placed top to bottom.
Any tips, ideas, workarounds?
Thu, Nov 12, 2009 at 4:29:50 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
JohanEkstrom
Sorry...of course it's the other way around. The paperspace is correct with top to bottom and the modelspace displays wrong with left to right...
Maybe I should get my lefts and rights sorted before tryin' anything else :o)
Thu, Nov 12, 2009 at 7:01:10 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
You will have to live with this I think but you might experiment with the order the views are placed on the sheet.
I really would not care what they are ion model space.
Thu, Nov 12, 2009 at 7:27:00 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
JohanEkstrom
Already tried to move around viewports, the order seems to be at random either way they're displayed. Was hoping for constructive workaround or somethin'
Don't wanna live with it and I refuse too :o)
It messes up our "sheets" in AutoCad...and to change it in AutoCad...well it's like it always is with that program...like drawing in Paint using MsDos...
Thu, Nov 12, 2009 at 9:01:28 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
I suggest you re-read my answer because what I told you to try works.  You did not do that.
To repeat... " you might experiment with the order the views are placed on the sheetThe order they are in model space is according to that order.
Thu, Nov 12, 2009 at 10:01:09 AM | Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
JohanEkstrom
Understood what you ment :o) Thanks...it's probably my english which is at fault.
But what I want to to is not possible...according to Autodesk. Unfortunately... But our company is startin' to program this function since there're apparently many companys asking for this. Impatient swedes refuses a no...
Thanks anyway!
importing Autocad files - modelspace & paperspace!
Tue, Jul 17, 2007 at 8:25:49 AM
Exporting sheets to dwg with shared coordinates
Tue, May 6, 2008 at 9:50:37 PM
inport dwg with paperspace views
Fri, Apr 9, 2010 at 8:34:13 AM
Exported AutoCAD file is too large
Tue, Jan 18, 2011 at 2:22:06 PM
Column Grid Text Exported into AutoCAD as Annotative Text
Wed, Jul 24, 2013 at 9:14:29 AM
Page generation time: 0.6753
