Forums >> Revit Building >> Technical Support >> Double Footing
Wed, Nov 11, 2009 at 3:23:56 PM | Double Footing
edpillsbury
So I added these footings using the wall foundation tool and it worked great...but these particular walls have gypsum on the inside, and when I unlocked the gypsum to pull it up above the finish floor things got confused and it made a double footing.
 Has anyone else seen this problem, or is it generally more reliable to use the foundation slab tool?  The wall foundation was almost too easy too use...
Thu, Mar 12, 2015 at 5:07:10 PM | Double Footing
AnaVg
I'm going through the exact same problem, even though I'm using Revit 2015! Is there still no solution?
Greetings!
AE
Fri, Mar 13, 2015 at 7:36:16 AM | Double Footing
I didn't remember that post from 2009 or even the similar post here that I responded to in 2012.  I re-tested it and it still does not function correctly so I would still do what I recommended in that other post.  Split the wall.
Edited on: Fri, Mar 13, 2015 at 7:36:45 AM
Fri, Mar 13, 2015 at 9:51:11 AM | Double Footing
AnaVg
Thank you WWHub, I'm using a structural wall family with 0.60m of thickness, for the moment, which is working fine. If this brings issues by the time I start the rebar process, I'll use your method, which is more true to the categories. Thanks!
AE
Double footing problem - plz help??
Thu, Nov 15, 2012 at 3:24:50 PM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:43 PM
Wall profile footing issure
Fri, Oct 3, 2014 at 7:06:49 AM
Page generation time: 0.0683
