5 Users Online (4 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Ceiling tile pattern
Wed, Nov 11, 2009 at 12:50:55 PM | Ceiling tile pattern
jcrocco
3 Stars: 1 Votes
It seems to be to be rediculous that the ceiling can have 2 different patterns, one on top, and the other on the bottom.  Too often, the pattern is correct in a ceiling view, but then in a 3D view from within the space, they end up wrong.  It wouldnt bother me if they both changed as you changed one side, and I kind of understand the reason for two different sided patterns.  However, there should be a toggle switch on the ceiling properties to have the top and bottom the same pattern, with the option on as a standard, and the option off to change it as you may want to.  Since I need to place light fixtures and air devices on the ceiling from a ceiling plan, it makes sense that the grid will also be designed in this view, moving and rotating as needed.  Unfortunately, the other side of the ceiling grid doesnt change.
Rotating CT tile patterns on floors
Mon, Oct 20, 2008 at 12:15:13 PM
Custom Ceiling Grid
Tue, Aug 7, 2007 at 2:41:37 PM
Make realistic tile pattern
Fri, Jun 25, 2010 at 9:43:53 AM
ceiling hatch pattern
Thu, Apr 17, 2014 at 6:59:10 AM
Tile Pattern Height
Mon, Oct 9, 2006 at 2:36:02 PM
Page generation time: 0.2527
