Forums >> Revit Systems >> Technical Support >> Hi Press & Lo Press Dom Cold Water
Wed, Nov 11, 2009 at 9:19:49 AM | Hi Press & Lo Press Dom Cold Water
koolair
4.5 Stars: 2 Votes
Hi everyone!
I have high pressure and low pressure domestic cold water systems from one booster pump.  The high side comes directly off the pump.  A branch is taken off, passed through PRVs and continue along with the high side.  My problem is as follows:
I've defined the DCW system from the pump, ie the pump family has connectors of the category "OTHER".  That way I can name the system whatever I want.  So when I tag the pipes the tag reads "50mm DCW (HP)".  For the low side, my idea was to modify the PRV family connectors from the default "GLOBAL" to "OTHER" so that I can rename the leaving pipe as something else.  When I put this modified PRV into the plumbing system and attempt to edit the system, I only get the opportunity to rename one system name (the one coming off the booster pump).  I thought I would be able to select both connectors on the PRV similar to the way I can select the inlet and discharge off the pump.
Can someone give me some hints?
Thanks.
printing press
Wed, Dec 29, 2010 at 11:28:44 AM
Press&Drag
Tue, Oct 16, 2012 at 1:43:13 PM
Domestic Hot water - No flow
Fri, Dec 11, 2009 at 3:50:05 PM
Video Tutorial - REVIT 2013 MEP Hot and Cold Water Pipe Routing
Thu, Nov 1, 2012 at 12:40:04 PM
Applying materials to new families
Wed, Sep 28, 2016 at 10:11:48 AM
Page generation time: 0.2459
