Forums >> Revit Building >> Technical Support >> Best Practices - Coordinating Column Grids Across Arch. and Structural Models
Wed, Nov 11, 2009 at 9:14:42 AM | Best Practices - Coordinating Column Grids Across Arch. and Structural Models
shannon712
Revit 2010.  What has been your experience coordinating column grids between structural and architectural models.  I would prefer to just link the structural model into my architectural model and use the grid lines from the linked file.  Basically draw one grid one time instead of having one grid in the arch model and a separate one in the structural.  The trouble is that I can't control the display of the bubble locations from the linked structural file in all of my views, particularly sections and elevations.
Is there a way around this, or do I just need to import the structural grid and try to make sure they match from file to file.  Will the interference checker help keep the grids coordinated?  I have not seen any documentation on this subject.
Wed, Nov 11, 2009 at 9:32:25 AM | Best Practices - Coordinating Column Grids Across Arch. and Structural Models
TKennedy
4 Stars: 8 Votes
You need to look into the "Copy/Monitor" tools.
Copy/Monitor Grids - can the edges move?
Wed, Feb 2, 2011 at 10:51:59 AM
Column to Grid
Tue, Sep 8, 2009 at 4:09:31 PM
columns grids not recognized
Wed, Oct 6, 2010 at 9:55:29 PM
Structural Columns moving on their own
Tue, Jun 21, 2005 at 11:10:20 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up
Wed, Nov 23, 2011 at 1:27:06 PM
Page generation time: 0.2642
