Forums >> Revit Building >> Technical Support >> Is is best to create walls all the way up or floor by floor??
Wed, Nov 11, 2009 at 8:51:13 AM | Is is best to create walls all the way up or floor by floor??
paolo1982
Im still undercided on whether its best if you have for eg - a 5 story building, is it best to create things like internal structural walls from ground to roof or is it best to do it from ground to 1st and copy to each level
 the reason i ask is that ive noticed that when you do them all the way up as the model gets bigger and you need to edit things it always detaches things from the walls, and can be a pain in the arse with slabs etc...
anyone got any good advice to what they think is the best was
Wed, Nov 11, 2009 at 9:31:18 AM | Is is best to create walls all the way up or floor by floor??
TKennedy
4 Stars: 8 Votes
When I was modeling stuff like structural cores, I tended to go floor by floor. I can't remember the exact reasoning right now, but it seemed to work out better.
Wed, Nov 11, 2009 at 11:14:33 AM | Is is best to create walls all the way up or floor by floor??
Exterior walls we model all the way.  We also model all the shaft type walls like masonry stairs and elevator shaft walls as full height.
I think most times, you should model it like you build it.  If the walls are built sitting on the floor ... model it that way.
Revit 8 -First Floor Roof Adjacent Second Floor Walls
Sun, Oct 1, 2006 at 7:57:59 PM
Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 19, 2014 at 10:32:39 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
Cut floor around walls
Fri, May 24, 2013 at 12:09:36 PM
pick walls to create floor
Tue, Apr 3, 2012 at 12:04:02 PM
Page generation time: 3.1850
