13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> Family - conditional formula
Somebody please advice on the issue below: E.g A cupboard has a parameter “LOCK” which can be set to true or false, if we set that to false, the cupboard shows up as “U5114” in bill of quantities, if we set it to true, it shows up as “U5114” and “LOCK1”.
Now on the implementation stage.... |
See attached snapshots for more details
HI RAMS, U ARE NOT USING ANY FORMULA IN ARRAY COMMAND, I'LL TRY FOR THAT. FIRST START A FAMILY WITH LINE BASED USING ARRAY COMMEND, ARRAY THE DIVEDER PANEL WITH FIX DISTANCE. AFTER THAT ASSIGN THE PARAMETER TO ARRAY NUMBER COUNTING, AFTER ASIGN THE PARAMETER TO ARRAY, GO TO FAMILY TYPE AND FIX THE FOURMULA WITH TOTAL HEIGHT BY DIVIDEING THE LENGTH WHICH U ASSIGN IN ARRAY COMMAND. IF U ARE UNABLE TO CREATE CONTECT ME AT KKGEMINI1@GMAIL.COM
Is it the right answer???????????
Wit conditional yes no, you don't need the =.... just If (Lock,result1,result2)
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:50 PM
conditional formatting yes no parameters |
Tue, Oct 28, 2008 at 9:58:54 AM
Yes/No Conditional on No/Yes |
Tue, Nov 11, 2008 at 12:21:06 PM
Schedule Parameter formula not showing up [ 1 2 ] |
Thu, Oct 28, 2010 at 4:33:57 PM
23
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
