21 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Converting from Revit 7 to 8.1
3 Posts No Rating |
I just upgraded from Revit 7 to 8.1 and when some components like toilets or bar stools do not show up in my 8.1 model. This is only the case a a few floors. For example the toilets and stools show up on the 1st for but don't show up on the 2nd flr. If I select window the are where the toilet doesn't show up in shows me the temp dims and the show the specifc toilet type in the drop down but I visualy can not see the toilet.....
Anyone have suggestions?
It may be a view range problem caused by the upgrade to the view. If the project is worksetted, be sure to run the Audit function to find any database problems.
HTH
Tom
3 Posts No Rating |
Finally found the problem here....
I went to the VV... and imported symbols... and turn on imported families...
These items are all items created from imported DXF ... drawings into a plumbing family... so they carry with it the imported families they need to exist...
Now I do not understand how they got turned off on some levels and not others during the import process... I think this is an easy fix.
Converting DWG materials to Revit Materials |
Thu, Sep 13, 2012 at 3:50:29 AM
converting masses? |
Wed, Nov 22, 2006 at 2:48:08 PM
Any known problems converting projects to 2009 form 2008? |
Thu, Aug 21, 2008 at 5:49:13 PM
Converting ! |
Mon, Oct 7, 2013 at 1:35:46 PM
Converting 3D objects from ADT to Revit families? Any suggestions? |
Wed, Nov 22, 2006 at 11:35:48 AM
