Forums >> Community >> Newbies >> CAST STONE HEADER OVER A WINDOW
Tue, Nov 10, 2009 at 2:02:32 PM | CAST STONE HEADER OVER A WINDOW
marc5
New to Revit.
My office bought Revit 2010 and I am learning it. Been on CAD for the last 11 years. In Revit I have done exterior walls, interior walls, doors, windows and storefronts. I am attempting to put a cast stone header over a window. The header needs to be 3-5/8" deep, 8" tall, 4'-8" long. What should I do or where in Revit can I read on how to do this?
Thanks for the advice.
Marc
Thu, Nov 12, 2009 at 9:54:19 AM | CAST STONE HEADER OVER A WINDOW
Dafpfy
3.5 Stars: 11 Votes
Edit the window familie or make a wall based familie with only the header?
if that answers your question?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Nov 23, 2009 at 7:53:32 PM | CAST STONE HEADER OVER A WINDOW
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I would try to avoid making a in-place family on this one. If you know anything about modeling i.e. extrusions, sweeps, blends voids. Then just open the window family and make a extrusion or sweep to model the way you want the cast stone. I would also put this on a sub catergory with in the family so you can change materials and line work if need be.
J. Allen Ball
SLOPING CAST STONE WINDOW SILL APPLICATION
Thu, Feb 28, 2013 at 8:38:42 AM
Arch Top Window Header
Mon, Mar 5, 2012 at 3:43:08 PM
Revit family visibility parameter question (Revit 2011)
Thu, Jun 9, 2011 at 10:14:20 AM
Arched window with stone arch above it? How to do it?
Wed, Apr 13, 2005 at 2:22:57 PM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:23 AM
Page generation time: 0.1628
