Forums >> Revit Building >> Technical Support >> Structural Connections / Mechanical Fixings
Tue, Nov 10, 2009 at 4:20:53 AM | Structural Connections / Mechanical Fixings
joachimmargarit
Hi im farily new to revit.
I'm currently working on Revit Architecture 2010 and have been for about a month. I have been creating quite a detailed model and at present our structural engineers do not use revit. My question is, what is the best method for creating structural connections? For example, i created bracket (see attached) by using a struct column famliy as a base and then changing the category to steel framing.
Initially I used "structural connections" as the category. However i was have difficulty viewing the brackets in my plan details and asumed it was because i wasn't using Revit Structure. There are a number of steel column connections/fixings that i need to model and it would be good to know what category and what family template is best suited to these. Eventually we hope to get the structural guys working on revit but for now i will need to do these in Revit Arch... Cheers.
Mechanical Equipment with Electrical connections showing 0V
Mon, Oct 11, 2010 at 8:13:43 PM
connections in the structural truss
Thu, Apr 4, 2013 at 10:38:14 AM
No Structural Connections Tag?
Fri, Jun 17, 2016 at 12:23:20 PM
KEYNOTING LINKS (structural, mechanical, electrical)
Fri, Nov 13, 2009 at 12:10:04 PM
Refrigeration related components
Thu, Aug 2, 2012 at 7:57:11 AM
Page generation time: 2.1731
