Forums >> Revit Building >> Technical Support >> Adding exterior trim to window
Mon, Nov 9, 2009 at 7:59:07 PM | Adding exterior trim to window
JARDesign
JARDesign Avatar
5 Stars: 2 Votes
I want to learn how to add a 1x4 wood trim to the outside of a window. Simple, I'm sure, but I want to add and I can't seem to figure it out
Tue, Nov 10, 2009 at 7:24:39 AM | Adding exterior trim to window
tim123
4 Stars: 19 Votes
You can create an in-place family using the wall category and just do a simple extrusion.  If there are a few you can create a face based family and do an extrusion, or insert parameters if the windows are all different sizes.
Tue, Nov 10, 2009 at 7:37:47 AM | Adding exterior trim to window
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
You could just add a few more ref planes and parameters to the window family, that way if any are different sizes it will automatically adjust
J. Allen Ball
Tue, Nov 10, 2009 at 8:27:34 AM | Adding exterior trim to window
JARDesign
JARDesign Avatar
5 Stars: 2 Votes
Okay.
Thanks for the answers, but I can crank out projects in revit (for a 52 yr old guy) but I'm having trouble with working with that stuff... work planes and parameters...
do I open the window family and how do I add that profile?
Exterior Window Trim
Thu, Jun 22, 2017 at 9:17:08 AM
13
exterior trim
Wed, May 28, 2008 at 2:19:54 PM
Need Help Adding Trim Boards
Thu, Mar 6, 2014 at 10:24:26 AM
Aligning window to wall's core exterior
Mon, Nov 22, 2010 at 12:33:49 PM
Windows, Walls, Trim
Mon, Jun 9, 2008 at 12:15:01 PM
Page generation time: 0.2790
