Forums >> Revit Building >> Technical Support >> light fixture height above floor
Mon, Nov 9, 2009 at 4:19:29 PM | light fixture height above floor
brainatoms
I am trying set a pendant light's height above finish floor, but when I create the parameter dimension from the bottom of the light fixture to the reference plane at 0'-0", it doesn't hold in the model (it seems to infer height from teh distance from teh ceiling). Is there any way to create a parameter for A.F.F. in a ceiling base fixture? This is especially troublesome for sloped ceilings.
Mon, Nov 9, 2009 at 4:53:51 PM | light fixture height above floor
Ceiling lights only relate to the ceiling - sorry.
If you have the pendent hanging depth as an instance parameter and you place a line in a section view, you can drag those lights down to the line for those sloped ceiling locations. You actually should be able to align them.  Remember to turn off always vertical on those pendents!
Edited on: Mon, Nov 9, 2009 at 4:56:25 PM
Mon, Nov 9, 2009 at 5:00:09 PM | light fixture height above floor
brainatoms
That's what I was afraid of.
Thanks,
Opaque light fixture not emitting light
Wed, Dec 18, 2013 at 3:30:34 AM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:38 PM
Lighting fixture not showing ANY light
Fri, Apr 10, 2009 at 12:30:55 PM
trying to make custom light fixture w/ 2 light sources - need help
Mon, Jun 22, 2009 at 6:23:45 AM
Generic Model turned Light Fixture not rendering
Thu, Aug 2, 2012 at 9:57:59 AM
Page generation time: 0.3827
