Forums >> Revit Building >> Technical Support >> Shared profile
Mon, Nov 9, 2009 at 2:58:31 PM | Shared profile
TKennedy
4 Stars: 8 Votes
I am suffering from a major case of cognitive flatulence today, but hopefully someone has an answer. I have a profile for a backsplash in my worktable family, and I would like to be able to select the profile type from the project. I thought I could simply make the profile family shared, but that doesn't seem to be an option, and I don't see where to tie a parameter to the profile in the worktable family. What am I missing?
Mon, Nov 9, 2009 at 3:21:55 PM | Shared profile
You actually used a profile family?  If so, just edit the family and load it into the project.
Mon, Nov 9, 2009 at 3:28:51 PM | Shared profile
TKennedy
4 Stars: 8 Votes
Yes, I used a profile family. It is loaded in the worktable family and the project. The backsplash profile is used in a sweep in the worktable family. What I want to be able to do is inside the project select a different profile for different sizes of backsplashes.
Tue, Nov 10, 2009 at 8:00:08 AM | Shared profile
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
you cant change a profile in a family threw a project, you will have to change it in the family.
J. Allen Ball
Tue, Nov 10, 2009 at 10:40:35 AM | Shared profile
TKennedy
4 Stars: 8 Votes
Ok, I must have been thinking of something slightly different. Thanks for the responses.
Tue, Nov 10, 2009 at 12:36:19 PM | Shared profile
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Oops...removed old post for lack of thought.
My bad
Edited on: Tue, Nov 10, 2009 at 12:44:39 PM
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Nov 10, 2009 at 12:51:07 PM | Shared profile
TKennedy
4 Stars: 8 Votes
Ok, I have the new parameter created, but I'm not seeing where I need to go to actually tie it back to the sweep.
Tue, Nov 10, 2009 at 2:10:00 PM | Shared profile
brettgoodchild
4 Stars: 17 Votes
I suppose one could make the sweeps as their own families and then load them into you worktabble family. Then just apply the Family type parameter to the profiles.
This way you would be switching backsplash types rather than profiles.
                             ~ Abraham Lincoln
Tue, Nov 10, 2009 at 2:13:43 PM | Shared profile
brettgoodchild
4 Stars: 17 Votes
and don't forget to constrain the nested sweep for length and height and whatever else is needed.
                             ~ Abraham Lincoln
Wed, Nov 11, 2009 at 9:40:38 AM | Shared profile
TKennedy
4 Stars: 8 Votes
Thanks, that's probably what I'll end up doing.
Shared parameters with profiles
Tue, Nov 23, 2010 at 1:27:31 PM
hosted profile vs. profile
Fri, Jun 5, 2015 at 2:10:31 PM
Scheduling Profiles?
Mon, Sep 10, 2007 at 9:55:34 AM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:40 AM
Metal deck roof profile
Fri, May 13, 2011 at 1:05:51 PM
Page generation time: 0.4866
