Forums >> Revit Building >> Technical Support >> window advice...2010
Mon, Nov 9, 2009 at 2:48:49 PM | window advice...2010
ejm159
I need to create a window for a project i’m working on. See attached.  Any suggestions that would get me going in the right direction would be greatly appreciated.
I need to put in a bunch so i want them to all edit together if i adjust one.
thx in advance,
eric
Mon, Nov 9, 2009 at 4:14:03 PM | window advice...2010
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Maybe this one could be useful for you, you just have to modify it.......
 http://www.revitcity.com/downloads.php?action=view&object_id=6327
Tue, Nov 10, 2009 at 7:49:48 AM | window advice...2010
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Have you worked with creating custom windows before?? this is a pretty easy one, you will just have to learn how families and parameters work.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Tue, Nov 10, 2009 at 8:40:32 AM | window advice...2010
ejm159
erland 73:  i tried that window yesterday but only 1/2 of it cut correctly into my wall.  other half was full of bricksWinking
allen Ball:  I watched a two part toutirial yesterday about creating window families and tried it w/out succes.  but after thinking about it last night as i was trying to sleep, i might have figured out my error.  I'm going to give it another try shortly after hitting the caffeine.
THANKS BOTH
Tue, Nov 10, 2009 at 10:44:59 AM | window advice...2010
ejm159
ok.  i made the window family by following the directions in this revit vid. http://www.youtube.com/watch?v=QIHVkUYSPjk the same way i did yesterday. Again, i have the some problem... the glass is not constrained to the frame. I don't understand...?
When i cnage the inset dim such that the window moves into the wall in plan the frame moves nicely leaving the glass out in oz.  THat will not pass the blower door test!
 Any ideas?
Tue, Nov 10, 2009 at 11:07:10 AM | window advice...2010
ejm159
 Any ideas?
Tue, Nov 10, 2009 at 11:08:59 AM | window advice...2010
ejm159
DON'T REPLY YET.  I THINK I HAVE IT FIGURED OUT......
Tue, Nov 10, 2009 at 11:31:40 AM | window advice...2010
ejm159
yup. it worksSmile
Tue, Nov 10, 2009 at 11:41:36 AM | window advice...2010
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
what was your problem??
J. Allen Ball
Tue, Nov 10, 2009 at 1:10:15 PM | window advice...2010
ejm159
i was missing a dim constraint on the glass. I thought i hade done that but some how missed that step.
Now the design is changing again and it looks like i'll need to do it all again.  blek!
need roof window advice...
Thu, Dec 10, 2009 at 3:21:12 AM
Advice from Professional Architects/Architectural Technicians
Wed, Apr 20, 2016 at 4:47:25 PM
WINDOW CUT PLANE IN 2010
Thu, Jan 7, 2010 at 10:38:27 AM
Suddenly can't insert window in project............
Wed, Aug 3, 2016 at 11:36:50 AM
12
Changing a family type (from door to window)
Mon, Aug 18, 2014 at 8:59:56 AM
Page generation time: 0.3132
