7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> wall floor connection
4 Posts No Rating |
if I make a simple floor in a new projct say 12' x12', then add 4 walls by picking the edges, how do I unjoin a given wall from the floor, so that I may move it without the floor stretching? easy one Im sure, its prolly staring me in the face revit2010 by the way thanks in advance rubiks
1 Posts No Rating |
You should just be able to click on the wall you would like to move and then click the unjoin geometry button and then click the floor that the wall is joined to.
4 Posts No Rating |
thanks patheh, but this did not work...any other suggestions?
What patheh should have said was to check this disjoin on the options bar. Now you can move the wall BUT ...... This will disjoin every element from the walls - floors - roof - walls - tags - dimensions ! The key here is how Revit builds associations. If the two items - wall and floor - have common definitions they will associate. But, if you build the floor without pointing to the wall and dimension it with locks, it will stay in place.
4 Posts No Rating |
thanks wwhub, but still nothing...I cannont find the 'disjoin' option anywhere when I select the wall chek attached rubiks
You have to pick the wall then the move - then you will see the disjoin option on your options bar.
4 Posts No Rating |
wwhub thanks that was it, i typically press and drag, which does not give the options.... cheers rubiks
The connection between wall and floor |
Fri, May 14, 2010 at 8:43:26 AM
Wall and floor connection/cut |
Tue, May 8, 2012 at 3:43:26 PM
floor to wall connection detail |
Mon, Jan 25, 2010 at 3:04:31 PM
Alternative to a VPN connection for worksharing - Faster remote connection |
Tue, Oct 12, 2010 at 8:51:02 AM
revit wall and beam connection |
Fri, Jan 9, 2015 at 6:01:21 AM
