Forums >> Revit Structure >> Technical Support >> Metal decks spanning in different directions on the same level
Sun, Nov 8, 2009 at 8:32:20 PM | Metal decks spanning in different directions on the same level
mark7321
I'm brand new in revit structure 2010 so bear with me. I outlined a floor slab for the entire level 1 floor of my project. It's one continuous enclosed "box" and revit structure accepted it when I finished my slab sketch. Then I realized that within this level of my project the deck needs to span in one direction for half of the level and span perpendicular for the other half of the level. Instead of outlining the entire level floor slab should I have outlined the slab area where the deck is going to span in one direction and closed that slab sketch and then create another slab and outline that area where the deck will span in the different direction? Is that the way it's done when the same type of floor deck size and slab thickness is used on a level when the deck changes direction? If so, will there be a line in the concrete slab where these two slabs intersect when I cut a section?
Mon, Nov 9, 2009 at 7:09:15 AM | Metal decks spanning in different directions on the same level
Although I don't have structure, I believe this will act just like other materials.  You will need a diierent floor for each span direction.  If there is a line at first, try your join geometry tool.  That should join the concrete.
Mon, Nov 9, 2009 at 9:10:55 AM | Metal decks spanning in different directions on the same level
TKennedy
4 Stars: 8 Votes
WWHub has it right. You need a different slab for each different direction, and you can join them to remove the line.
Mon, Nov 9, 2009 at 7:52:16 PM | Metal decks spanning in different directions on the same level
mark7321
Thanks WWHub and TKennedy for your replies. It worked.
creating a corregated metal roof
Mon, Oct 1, 2012 at 1:20:26 PM
Room spanning multiple floors
Tue, Jun 17, 2008 at 3:13:13 PM
Area Schedules
Tue, Jan 21, 2014 at 7:17:28 AM
Stairs & Decks
Wed, Aug 1, 2007 at 5:00:33 PM
Ceilings sloped in two directions?
Thu, Nov 11, 2010 at 12:07:26 PM
Page generation time: 0.6745
