Forums >> General Discussion >> Revit Project Management >> MEP link to Architecture slow down
Sat, Nov 7, 2009 at 9:32:45 AM | MEP link to Architecture slow down
lpnoble
I am reaching the end of a a average two story building with average complexity.
I have linked the MEP file and have it isolated to a separate work-set. This work set is off for all views. for the views that need the MEP background I turn on the work-set in that view only.
 As we work it is clear that the MEP file is very CPU intensive. the machine is very slow to display and changes take time to update in the view.
Is the MEP file doing many calculations to develop the geometry? If so, can this be avoided? I am thinking of creating a proxy file made up of exported geometry in dwg or some other format and relinking but the is a work-flow nightmare.
Does anyone have experience/thoughts on this?
Fri, Dec 11, 2009 at 3:53:10 PM | MEP link to Architecture slow down
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
as a user of mep, now you know why we all curse so much...the mep model is not doing any calc for geometry at the point where you are using it...the geometry itself yes is being regenerated though in all views...a proxy may work it would certainly move quicker..defeats the purpose of us creating a model though
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Linking Revit MEP, Structural Models into Revit Architecture
Mon, Apr 23, 2012 at 4:00:03 PM
Is there anything Revit Architecture can do that MEP can't?
Fri, Apr 17, 2009 at 5:10:43 PM
MEP and Architecture Intigration
Fri, Sep 25, 2009 at 2:22:32 PM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP
Thu, Aug 26, 2010 at 7:48:24 AM
Transferring components
Fri, Aug 12, 2011 at 6:59:25 AM
Page generation time: 1.8089
