Forums >> Revit Building >> Technical Support >> Detail callout tag... for 2010
Fri, Nov 6, 2009 at 5:30:13 PM | Detail callout tag... for 2010
HGL5
Similar to a callout tag or a section cut is tied to their drawings, I want a tag (circle with a horizontal line, detail number on top, sheet number on bottom) tied to a drafting view detail.  Can someone let me know if this is possible and how to do it? thank you for your help. Basically I need something like the Callout tag (then reference my view) but I dont want all the callout box that goes along with the reference tag
Edited on: Fri, Nov 6, 2009 at 6:23:53 PM
Sat, Nov 7, 2009 at 12:10:13 AM | Detail callout tag... for 2010
tim123
4 Stars: 19 Votes
You can overide the properties of the callout boundary and leader line in object styles.  If you make them white they become invisible.
Tue, Nov 10, 2009 at 11:30:50 AM | Detail callout tag... for 2010
HGL5
overriding the leader lines to be white affects all callout tags though. I was hoping that after I duplicated the default callout tag, renamed it detail tag, I could go into type properties and select no leader lines or callout box.  Is that not possible?
Wed, Nov 11, 2009 at 2:14:07 AM | Detail callout tag... for 2010
HGL5
Finally found a decent workaround for now... Select the callout, right click, override graphics in view, by element, change line wt to 1 and color to white.
Wed, Nov 11, 2009 at 11:58:51 AM | Detail callout tag... for 2010
Use a very-very small call-out bubble.  One that basically is part of the bubble line.
detail callout tag, multiple times on the same view
Thu, Oct 8, 2009 at 1:16:25 PM
Callout Tag - referencing a floor plan - reflected ceiling?? (2010)
Wed, Nov 11, 2009 at 1:08:38 PM
detail callout tag and section symbols
Mon, Nov 22, 2010 at 6:30:43 AM
Callout Tag Appearing in All levels
Tue, Mar 30, 2010 at 6:43:40 AM
CALLOUT
Tue, Jan 31, 2006 at 5:02:58 AM
Page generation time: 0.6103
