Forums >> General Discussion >> Wishlist >> Find & Replace
Fri, Nov 6, 2009 at 3:21:01 PM | Find & Replace
Idealist
First and foremost - I've never needed it yet, but some reading leads me to believe there is no find and replace tool for text in Revit.  That would surely be a useful tool, but I like to think big picture.
Wouldn't it be nice if there was a find and replace tool for model elements?  Say you place 10 very generic toilets at the begining of a project.  Later you want to go back and replace some of them with toilet A, others with toilet B, and some you want to leave the original.  The tool would be most useful if it had the same options as the MS Word find & replace tool.
I'd love that tool.  Please Autodesk, make our dreams come true!
Fri, Nov 6, 2009 at 3:29:16 PM | Find & Replace
2010 has a find and replace for text...
There has always been a find and replace for model objects - find one - right click and select select all, then change the family or type on the options bar.
Mon, Nov 9, 2009 at 10:22:45 AM | Find & Replace
Idealist
Awesome about the text find & replace.
For the families - yes, I understand you can do all of them at one time that way.  But I want to be able to individually examine each instance of the family before I decide if it needs to be replaced or not.
Mon, Nov 9, 2009 at 10:43:30 AM | Find & Replace
When I have something like that, I use SA to isolate the objects in a view... like a floor plan - or even 3D.  Just use the SA from the plan then click on the sun glasses and isolate those objects in the view.  Now you can inspect each one.
Thu, Dec 3, 2009 at 4:15:22 PM | Find & Replace
ranttila
where can i find the find and replace tool in 2010?  i think i'm missing something...
Thu, Dec 3, 2009 at 4:22:36 PM | Find & Replace
ranttila
(for text, that is)
Mon, Dec 21, 2009 at 2:43:00 PM | Find & Replace
MARS1276
1 Stars: 1 Votes
Ditto.  I would like to know where that is as well!
Mon, Dec 21, 2009 at 3:14:44 PM | Find & Replace
Under the annotate tab - text - right next to the spelling guys.
Mon, Dec 21, 2009 at 3:20:04 PM | Find & Replace
ranttila
the only option i have next to spelling is tag by category, meaning my only options in the text section of the annotate tab are text and spelling...is this in one of the updates?
Mon, Dec 21, 2009 at 3:40:36 PM | Find & Replace
Must have been - see image....
Mon, Dec 21, 2009 at 4:27:59 PM | Find & Replace
#11
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Yeah...it's part of the subscription advantage package
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Sun, Feb 21, 2010 at 10:40:53 PM | Find & Replace
#12
spacey
I have a 2010 subscription, but not the Find and Replace as shown in the image. Is there a special package I need to download or sign up for to get it?
Mon, Feb 22, 2010 at 7:18:18 AM | Find & Replace
#13
The Subscription Advantage Pack for Autodesk Revit Architecture 2010 is available at the Subscription Center. You can access the Subscription Center at http://www.autodesk.com/subscription.
Mon, Feb 22, 2010 at 7:48:01 AM | Find & Replace
#14
pdoug
3 Stars: 2 Votes
WWHub,
I am not totally familiar with the subscription center even though I am a member.  I use RST2010 and I thought I had the latest version installed.  When I get into the subscrpition center - downloads area I see the download for Revit Structure 2010.  There is a link to details but they do not tell me what version or build this particular download is for...how do you tell if this a newer, older or same version of the software already installed?  Thanks- Patrick
Mon, Feb 22, 2010 at 9:27:05 AM | Find & Replace
#15
gebber
gebber Avatar
5 Stars: 4 Votes
Patrick,
it's not a full version it's a Subscription Advantage Pack.
So when you connect to the Subscription centre don't check under download your software but scroll down tot the product add-on section.
Here you can choose; *Subscription Advantage Pack for Autodesk Revit Architecture 2010, you can down several add-on's here.
Find&Replace revit Components - is there an option like that?
Tue, Jun 25, 2013 at 7:25:19 AM
Find & Replace???
Sun, Oct 16, 2005 at 5:54:15 PM
Find/Replace Text
Tue, Dec 23, 2014 at 1:33:02 PM
Find and Replace Materials for Revit
Sat, May 6, 2017 at 7:10:35 PM
Find and Replace Text Command
Wed, Oct 18, 2006 at 12:25:13 PM
Page generation time: 2.5289
