Forums >> Revit Structure >> Technical Support >> Need help: modeling tube to tube intersection w/ in-place families
Fri, Nov 6, 2009 at 2:44:04 PM | Need help: modeling tube to tube intersection w/ in-place families
structuresguy
I have a decorative eyebrow frame that is mounting to my building that the architect insists we show in our model.  It has a 12" round aluminum tube running horizontally along the wall, about 12" off the wall, with a 8"x12" rectangular tube bracket back to the wall.
I want to use in-place families, so that in plan I see the full shapes.  If I use HSS tubes from the beam menu, in plan I would only see the centerline.
I can create all the shapes, but in-place families won't cope to each other (what a PITA!!!).  REVIT GODS - YOU NEED TO ADD THIS FUNCTIONALITY!  Anyway, I also want to create one in place family with all the parts.  But when I create a void form to shape the 8x12 tube to cope around the 12" round tube, it also cuts through the round tube.  Is there any way to get a void only to affect one part of the family?  Or do I need to make two separate families?
Alternatively, I would usee HSS beams if I could show them in fine detail on plan, when the rest of the plan is course.  Is there a way to overide the detail level by element?
Thanks.
Fri, Nov 6, 2009 at 2:46:37 PM | Need help: modeling tube to tube intersection w/ in-place families
structuresguy
The sketch I attached is made with HSS beams, with a 1" coping distance.  This is how I want my in-place family to look, but with zero coping distance.  But I can't get it in one family.  It just seems to be I should be able to build-up a complex shape with several extrusions/voids, and be able to define how it fits together.
Fri, Nov 6, 2009 at 3:03:32 PM | Need help: modeling tube to tube intersection w/ in-place families
If you use the join on the two items, the void will cut both...so don't do that.  Then ... try making the void to the side - when finished, slide it into place and then select it and tell it which items to cut.
Wed, Nov 11, 2009 at 7:15:36 PM | Need help: modeling tube to tube intersection w/ in-place families
emgeeo
3.5 Stars: 7 Votes
You've got the right idea, you just need to adjust the extensions and coping distance.  In the screenshot I've posted, i used a 4" extension with a 0" cope.  See screenshot.
As for the graphics issue...I'll use an hss for the example
1.  Edit the HSS family.
2.  Save as 'HSS - Eyebrow' or something that pertains to the area you are working in.  It's very important that you save this as a new family!
3.  Go to a side view in the family (right or left) and delete the geometry for medium-level detail.  This will be the hss shape without rounded corners.
4.  Select the remaing geometry in the family.  In the editing bar, you will see a 'visibility' button (which can also be accessed by right clicking while your hss geometry is selected).  Click it.  Select all three options for detail level.
5.  Still editing the family - go to settings -> family categories and parameters.  Select 'from family' for symbolic representation.
6.  Load into project.
These HSS shapes will not appear in fine detail - regardless of graphics level you have selected.
Make sense?
Edited on: Wed, Nov 11, 2009 at 7:30:10 PM
3D Curve Tube
Sat, Dec 31, 2011 at 3:02:26 PM
Wiring a 3 tube light
Thu, Jun 23, 2011 at 3:01:48 PM
Cut a window into a tube
Mon, Feb 13, 2006 at 4:29:00 AM
cutting a HSS tube
Wed, May 23, 2012 at 2:06:22 PM
Cannot add sub-family to HSS Steel Tube Sections
Thu, Sep 22, 2011 at 3:02:35 PM
Page generation time: 2.8808
