Forums >> Revit Building >> Technical Support >> Wall Sections
Thu, Aug 25, 2005 at 4:07:54 PM | Wall Sections
meinarch
When working with wall sections, materials that should "join" or "cut" other materials don't seem to be doing so - i.e. structure (1) cutting thru finish (1) etc. Any thoughts on what I may be doing wrong or may not be doing?
Thu, Aug 25, 2005 at 4:39:32 PM | RE: Wall Sections
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not sure what the issue is exactly, maybe if you upload a sample file with the loaded wall types showing the incorrect intersections. Technically a layer set to structure (1) should cut a layer set to finish (4) or (5)...?
From Wall Sections to Drafting Views
Fri, Sep 25, 2009 at 10:22:08 AM
Wall Sections disappearing?
Tue, Aug 21, 2007 at 1:13:29 PM
Custom Wall Sections
Sun, Aug 7, 2005 at 10:05:54 PM
Problem with wall sweep show on wrong sections
Wed, Mar 22, 2006 at 5:37:32 AM
Revit 2017 Mising Wall Sections
Mon, Jul 18, 2016 at 5:53:08 PM
Page generation time: 2.6557
