Forums >> Revit Building >> Technical Support >> Mullions disappear after exporting from Revit
Thu, Nov 5, 2009 at 2:52:12 PM | Mullions disappear after exporting from Revit
fkareem384
Please help! After exporting a Revit view to CAD. All the mullions in the curtain wall and storefronts are no where
to be found! Please advise as I have a deadline tomorrow. Could it have something to do with the system families?
Help!!!!!!
Thu, Nov 5, 2009 at 3:09:54 PM | Mullions disappear after exporting from Revit
Has anyone messed with your CAD mapping?
Thu, Nov 5, 2009 at 3:14:52 PM | Mullions disappear after exporting from Revit
fkareem384
I have altered the Layer Mapping File in Revit. I currently have all mullions to map to an A-GLAZ-CWMG Layer in AutoCAD.
The mullions are not showing up at all though. Did I mess something up in my Layer Mapping file? I did save the mapping
file that I did so I can load the default Mapping file. What do you think is wrong? Is this something you have heard
of before?  Any information would be great. Thanks in advance!
Thu, Nov 5, 2009 at 3:17:12 PM | Mullions disappear after exporting from Revit
Why don't you test the default - if it works then you did something wrong.
Thu, Nov 5, 2009 at 3:25:39 PM | Mullions disappear after exporting from Revit
fkareem384
I just tested the default file. I get the same result. Still no mullions. I have noticed that all the mullions in the file
are a 2.5" x 6" rectangular mullion. I also noticed when I go to the type properties for this particular mullion there is not a preview
 available for it. Not sure what's going on there.
Selective 3d Exporting
Thu, Feb 12, 2009 at 1:53:21 AM
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:19 AM
Mullions within in panel family
Mon, Jun 12, 2017 at 2:32:28 PM
trimming vertical mullions to continuous border mullion
Tue, Aug 13, 2013 at 5:28:05 PM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:15 AM
Page generation time: 3.4963
