23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> text spacing different b/w screen and plot
5 Posts No Rating |
I've scoured the websites and forums, I've searched Autodesk help, I've reached desperation.Here's my problem:I am just starting to get into transferring out office over to Revit. We have been using the font: gill sans MT as our office standard. I have set up all of the tags and labels with this font and it appears perfect on screen. When I go to print, it squishes the font spacing to zero. Do you know what could be causing this? When I change the font to arial, it prints with no problem. Thanks Brenda
How are you printing and to what? Did you try printing to PDF then sending that?
5 Posts No Rating |
I have tried printing to file, printing as PDF, and printing to 2 different Xerox printers. All have the same result. As soon as I change the font to something more common (in this case: Arial), it will print in any of the methods above without a problem. Thanks, Brenda
I printed to cute pdf and it is fine with that font here. Something wrong in your system.
5 Posts No Rating |
hmm. what would you recommend? I am running revit arch 2010. This problem is ongoing...so over several days, revit and my computer have been restarted. Brenda
5 Posts No Rating |
well, i found a temporary way around the issue so that i can get these drawings out: by exporting as a dwf, the fonts do not squish or change spacing. brenda
5 Posts No Rating |
So...6 weeks later, I finally had time to resolve this issue correctly. When I would send to our Xerox plotter, the fonts would print accurately. When printing to the Xerox copier (11x17 format), the font/character spacing would not print as displayed on screen. Same issue when printing as a PDF. Turns out, the driver (post script) could not handle something with the font. I went to the Xerox support page and downloaded a PCL driver. Issue: resolved. Now...how to solve the same problem with our PDF print driver...
Text format difference between screen & plot - Revit 2009 |
Tue, Jan 25, 2011 at 4:00:24 PM
creste non-plot lines and text |
Tue, Jun 23, 2009 at 11:38:18 AM
Text line height spacing - can it be changed like the width? |
Thu, Dec 12, 2019 at 4:29:09 AM
print differs from screen |
Fri, Jun 26, 2009 at 9:30:16 AM
Linked AutoCad text emergency |
Mon, Mar 10, 2008 at 12:56:06 PM
