Forums >> Community >> Newbies >> Footing joins to gravel, not slab
Thu, Nov 5, 2009 at 12:03:06 PM | Footing joins to gravel, not slab
trialbyfire
Revit Structrure 2009 -
I have a slab on grade floor with concrete o/ sand o/ vapor barrier o/ gravel.
How do I make my ftg join to theCONCRETE instead of the gravel base??  Both are set as the same material (cast in place concrete).
See the attached pdf.
Thanks
Fri, Nov 6, 2009 at 12:53:11 PM | Footing joins to gravel, not slab
In your floor structure, move the "gravel" out of the core... and why is is set to concrete?
Fri, Nov 6, 2009 at 5:34:16 PM | Footing joins to gravel, not slab
trialbyfire
Thank you W.  Your layering comment solved a couple other issues I was having, but I'm still having problems with this situation.
Why is what concrete?  My slab and spread footing are cast in place concrete, the gravel and sand are "Site - Gravel "and "Site - Sand" material.
Edited on: Fri, Nov 6, 2009 at 6:10:49 PM
Fri, Nov 6, 2009 at 6:07:20 PM | Footing joins to gravel, not slab
trialbyfire
OK, here's an example of where it's still not working, even with your suggestion.
The first pic is BEFORE I've joined the footing to the slab, and the properties of the slab are shown for reference.
The second pic is AFTER I've joined the footing to the slab, and the properties of the ftg are shown for reference.
How come the footing is joining to the gravel and not the concrete slab?
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
lower interior footing to match foundation wall footing
Tue, Mar 5, 2019 at 3:06:52 PM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Double footing problem - plz help??
Thu, Nov 15, 2012 at 3:24:50 PM
Wall Footing for copy monitored element.
Tue, Jan 22, 2008 at 4:25:40 PM
Page generation time: 0.0949
