Forums >> Revit Systems >> Technical Support >> drafting views pen weights light with linked .dwg
Thu, Nov 5, 2009 at 9:45:20 AM | drafting views pen weights light with linked .dwg
Cvanmeter
Hoping someone can help me out, i have some .DWG details that i have linked into drafting views. when the .DWG files are brought into revit this way they are very light. if i just link them directly onto a sheet the pen weights are fine. i have tried everything i can think of and am having no luck. the files are drawn in paperspace in the dwg so they are brought in as 12"=1'.
 i would greatly appreciate any suggestions you might have.
Thanks;
Cvanmeter
Fri, Nov 6, 2009 at 12:58:02 PM | drafting views pen weights light with linked .dwg
First suggestion... don't do that.  Linked CAD files will get you in trouble.  They will really bog you down over time.
Everything in REVIT is controlled through VG settings.  Whether at the project level or the view.  At the project level - Look under Settings/Object styles Imported... and when you expand, you will find your layer names andassociated pen / linetype settings.  Similar settins in views (VG) and families.
Setting up Views with proper pen weights and color for individual disciplines
Tue, Mar 22, 2016 at 7:33:36 AM
Reveals and pen weights?
Thu, Oct 26, 2006 at 10:14:48 AM
printing too light and single pen
Mon, Jun 1, 2009 at 7:49:06 AM
Assign colour to 'Pen Weights'
Fri, Jun 12, 2009 at 7:55:10 AM
Exporting revit drawings to .dwg
Wed, Aug 10, 2005 at 10:36:23 PM
Page generation time: 1.4361
