Forums >> Revit Building >> Technical Support >> Symbol lines in both ceiling and floor plans
Thu, Nov 5, 2009 at 9:38:15 AM | Symbol lines in both ceiling and floor plans
adeuley
I am trying to create some 2D tags that need to show up in the floor plan and the ceiling plan.  I am currently inserting the tags at an offset between 6' and 7' and adjusting the cut planes of the views accordingly.  I think there should be a way though to make a tag and have it show up in the same location on the floor and ceiling plan.  I am using symbol lines to make the shape of the tag.  There is a different shape for the floor plan and the ceiling plan. I tried creating a second reference plan and placing the ceiling tag on that plane. All I end up with is both tags on both planes. Thanks for your help
Fri, Nov 6, 2009 at 1:01:55 PM | Symbol lines in both ceiling and floor plans
Tags are 2D elements.  2D elements are all view dependent and the element has to be in the view (or an invisible part of the family has to be cut by the view) in order to be tagged.
Lines in Ceiling Plans
Wed, Oct 24, 2007 at 4:44:57 PM
Floor Plans need to show Ceiling on them in Revit 2011
Thu, Aug 26, 2010 at 12:40:35 PM
Drawing lines on floor plans
Fri, May 19, 2017 at 12:54:00 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting
Tue, Sep 13, 2011 at 11:12:09 AM
Grid lines moving together in different floor plans
Mon, Sep 20, 2010 at 9:10:52 PM
Page generation time: 0.5984
