Forums >> Community >> Newbies >> Elevated slab joins.
Wed, Nov 4, 2009 at 1:01:16 PM | Elevated slab joins.
Memnon
Memnon Avatar
Hi all.
Firstly I wanted to say I'm new here and new to Revit. So far it seems very cool and I'm having a great time learning this but I'm having a bit of a problem. I am practising my skills by attempting to model the apartment complex I live in. The building is built on a slope (2 maybe 3 degrees) so the slabs are elevated 2 feet every 20 feet. Elevating the slabs isn't really my issue. Joining them together is my question. How can I join the slabs with a 2 foot elevation from each other?
I sketched what I wanted to the end result to look like. with the vertical 2 foot section of concrete. I also included a pic of where I am at with this problem in Revi. I'm using Revit Architecture 2010 student license btw.
Should I actually draw a vertical 2 foot section and then use Join Geometry on both slabs? Can I create a custom wall that has the concrete in it and the plywood/drywall layered over it? This elevation will be repeated about 5 times in the model.
Wed, Nov 4, 2009 at 1:26:04 PM | Elevated slab joins.
4 Stars: 205 Votes
Create a wall with the same material of the slab then use the "Join Geometry" tool, the other wall (in top) "Modify" the "Gypsum" UNLOCK that layer then you can Stretch that like you can see in the images....
Thu, Nov 5, 2009 at 11:32:27 AM | Elevated slab joins.
Memnon
Memnon Avatar
That turned out to work pretty good. Thanks for your help. Smile
Edited on: Thu, Nov 5, 2009 at 11:34:25 AM
Edited on: Thu, Nov 5, 2009 at 11:36:20 AM
Elevated sidewalk
Fri, Sep 2, 2005 at 11:03:15 AM
Beam and slab connection
Fri, Oct 3, 2008 at 4:52:10 PM
Slab Edge Visiblity Issue?
Tue, Dec 22, 2009 at 6:10:09 PM
Slab Edge Profile... Except Up...
Wed, Nov 11, 2009 at 7:00:24 PM
Footing joins to gravel, not slab
Fri, Nov 6, 2009 at 6:07:20 PM
Page generation time: 0.0768
