Forums >> Revit Building >> Technical Support >> How to Make random depth dimension in a nested family.
Wed, Nov 4, 2009 at 4:33:50 AM | How to Make random depth dimension in a nested family.
babysaks
Hello everyone; i made this tutorial:  http://designreform.net/2008/10/revit-nested-families/
I have a tricky question for you though and because i’m kind of new on this parameters formulas.  I pretty much followed the video step by step, and at first i though everything would be parametric ( width,height and depth). But now i see that its only width and height because they are dependent on the size of the curtain grid and the depth it’s conditioned with a formula; My question is: I would like my width & height be the same,i.e. 1 mt. ( square ) so i would need to make the curtain grid with the same dimensions in horizontal and vertical…but how could i make the depth of those squares to be random? Or to be at least between 2 numbers? Like .5 mt & 2.5 mts?. Thank you so much for your help ! <img src=" /> Pao
Here's a pic of the final result: But this image it's when the depth depends on the (width*height)/5.
And i need width & height to be the same and with a customizable depth ( random if possible)
Thu, Nov 19, 2009 at 8:56:26 PM | How to Make random depth dimension in a nested family.
hisdirt
5 Stars: 5 Votes
Im interested in this aswell, is there a formula imput 'random'?
Would be very interesting to see the creative potential of a constantly changing value...
Nested Family won't lock to 2 ref planes/lines
Fri, Jan 17, 2014 at 10:09:19 AM
nested family rotation
Tue, Sep 3, 2013 at 1:25:41 PM
Families - How do you dimension to a cut extrusion
Fri, Mar 19, 2004 at 8:49:04 AM
array of nested objects
Tue, Oct 14, 2014 at 2:27:27 PM
Nested Family Count in Table
Mon, Jan 15, 2018 at 11:47:52 AM
Page generation time: 2.8067
