Forums >> Revit Building >> Technical Support >> Curtain Wall
Thu, Aug 25, 2005 at 1:16:15 PM | Curtain Wall
rudolfweyers
How can ?I change the material of a curtain wall, so that the glass appears darker
Thu, Aug 25, 2005 at 2:25:12 PM | RE: Curtain Wall
Xane
By default it is 'glass' material. You can change this material in 'material settings' or define your glass (etc. glass 1) and in 'object styles', expand row 'curtain panels' where you find new row 'glass' at the end of row you can put your material (etc. glass 1)
Tue, Aug 30, 2005 at 12:26:22 AM | RE: Curtain Wall
Audrie
Is it possible to treat the curtain wall panes individually and put tints to some panes and not others?
Tue, Aug 30, 2005 at 4:54:10 AM | RE: Curtain Wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Of course. In the project in your browser window, scroll down to families-->Curtain Panels-->System panel And duplicate types with different materials and then sub in those panels for the existing ones in your curtain walls.
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall
Sat, Jan 10, 2009 at 10:01:35 AM
Page generation time: 1.9707
