Forums >> Revit Building >> Technical Support >> Filtering objects that do not have their category listed in the Filters Setup...
Tue, Nov 3, 2009 at 11:25:29 AM | Filtering objects that do not have their category listed in the Filters Setup...
cobblea
I am trying to set up a filter to apply to wall sweeps (rubber bases in particular).  Once applied, I would then use view templates to hide all of them in every view except interior elevations and sections.  Is there a way to get the filters to apply to objects when the Wall Sweep Category is not listed in the filter dialogue?  I suppose I could set up a workset for this task, but I would prefer not to do it this way.  Maybe someone else has a better way entirely?
Thank you in advance.
Tue, Nov 3, 2009 at 11:48:35 AM | Filtering objects that do not have their category listed in the Filters Setup...
If your sweep is part of the wall, you will not be able to control it... one of Revit's problems.
Wed, Nov 4, 2009 at 10:39:52 AM | Filtering objects that do not have their category listed in the Filters Setup...
ebtaylor
3 Stars: 2 Votes
There's another way but it could be somewhat tedious depending on how many wall sweeps you have. I have found if I add a parameter to my project and then select all categories. I can then use it for anything. Example, we had a project with many flat screen tvs and by using the project parameter I typed in 42"TV, then I created a filter from the project parameter that contains 42"TV. From there I was able to add the fitler to my views I didn't want to see the tv's and the one view I wanted to see them I was able to half tone everything but the tv's.
I've also found many more other uses for the project parameter, very useful tool.
Hope this helps
Wed, Nov 4, 2009 at 11:17:38 AM | Filtering objects that do not have their category listed in the Filters Setup...
ebtaylor - that process works for almost evrything but wall sweeps embedded in a wall definition are different.  They are part of the wall.
applying colors in Filters in different floors in one project
Mon, Oct 17, 2011 at 8:45:51 AM
Objects constrained to level ...
Wed, Feb 3, 2010 at 6:28:25 PM
Worksets and Filters
Wed, Mar 2, 2011 at 10:32:41 AM
Project Browser
Mon, Jan 19, 2015 at 7:54:23 AM
how visibility of filter work with the turn on/off of certain category?
Thu, Jan 13, 2011 at 4:03:48 PM
Page generation time: 0.2365
