Forums >> Revit Building >> Technical Support >> Titleblock issues
Tue, Nov 3, 2009 at 8:24:47 AM | Titleblock issues
fkareem384
I am new to Revit City. I am currently working on Revit Architecture 2010. I have been put in charge of
exporting our revit files to CAD.  This includes the titleblock. Is there a way I can export the titleblock (30X42) to CAD
without having to change the settings in CAD? Every time I export the Revit title block I have to adjust the page set up in
to match what I had in Revit. Please help!!!!!!
Wed, Nov 4, 2009 at 5:02:55 PM | Titleblock issues
emgeeo
3.5 Stars: 7 Votes
What do you have to change in AutoCAD?
Thu, Nov 5, 2009 at 8:00:41 AM | Titleblock issues
fkareem384
I  have to change the actual lay out tab in CAD to make sure it matches a 30X42 sheet size which is what the titleblock
is based off of in Revit. It comes in on a 8.5 X 11 lay out tab in CAD. I want it to have the lay out tab already adjusted
for a 30X42 sheet size when I open the exported Revit file in CAD.
Fri, Nov 6, 2009 at 1:02:16 PM | Titleblock issues
emgeeo
3.5 Stars: 7 Votes
I'm not running into that problem right now, but I know it's happened in the past...
Are you exporting from the project or the family?  Perhaps that could have an effect.
Are you exporting for CAD users?  Don't they need the titleblock to be in modelspace anyway?  We usually have a model-space titleblock xref'd into our layout tabs....
Don't know what to tell you.
Scale Issues in Titleblock
Thu, May 2, 2013 at 5:01:38 AM
Creating Custom Titleblock - Display Issues
Tue, Feb 25, 2014 at 1:56:42 AM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Help with some Titleblock issues... I just have a couple questions.
Sat, Sep 13, 2008 at 12:41:41 PM
Titleblock issues
Thu, Oct 8, 2009 at 3:04:24 PM
Page generation time: 0.1557
