Forums >> Revit Building >> Technical Support >> Some imported DWGs have no line weights
Mon, Nov 2, 2009 at 5:25:34 PM | Some imported DWGs have no line weights
elduderino1234
Revit 2009
 We have been doing our details in AutoCAD and importing them into Revit. I set up the import settings in order to give thickness to various lines. However, sometimes when we import drawings, all of the lines have a #1 Revit pen thickness. Has anybody come across this before and know how to remedy it? Thanks
Tue, Nov 3, 2009 at 7:00:40 AM | Some imported DWGs have no line weights
Read this in your HELP Setting Line Weights for Imported DWG or DXF Files
Once imported though, you can change the settings under settings/object styles
Line Weights in Imported CAD drawing - Change weights but not scale?
Thu, May 17, 2012 at 2:02:02 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Imported DWGs not exploding?
Tue, Feb 8, 2005 at 9:11:31 PM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
CAD inport layers and line weights and shading
Fri, Apr 6, 2012 at 7:35:43 AM
Page generation time: 1.0081
