Forums >> Revit Building >> Technical Support >> Deleting multiple line patterns...
Mon, Nov 2, 2009 at 10:49:54 AM | Deleting multiple line patterns...
arusso5
I hope this is a simple answer... I have a ton of unwanted Line Patterns in my template file that I need/want to delete.  It's a long story, but they are there.  Is there an easier way to delete them that going to Manage/Line Patterns and deleting one at a time?
Please tell me there is... thanks.
Mon, Nov 2, 2009 at 11:18:30 AM | Deleting multiple line patterns...
I think you should tell the story so others don't make the same mistake.  I would assume they are exploded CAD files.
If you really have a lot, then your out mabe to start a new template and trasfer project standards from the bad one excluding the line patters (a whatever else is bad).  This will not get you legends / schedules and sheet setups but you should be able to copy paste most of that.
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Tile Patterns, not line patterns
Fri, May 17, 2019 at 9:29:04 AM
Fill Regions not deleting
Thu, Oct 8, 2020 at 3:52:54 PM
Importing multiple fill patterns
Fri, Jun 22, 2007 at 11:50:50 AM
Line Patterns
Tue, Aug 9, 2005 at 3:08:30 PM
Page generation time: 0.9433
