Forums >> Revit Building >> Technical Support >> Current Revision Date in sheet index
Mon, Nov 2, 2009 at 10:49:31 AM | Current Revision Date in sheet index
dssrevit
HUD Projects require the sheet index to have a column with the current revision date of each sheet listed.   When create a sheet index schedule, the only columns that can be added is the revision number, or issue date.  We need to have the ability to add the current revision date, but do not see that as an option,  Is it possible to create a custom parameter that will look up the current revision date for that sheet to populate this need or do we simply have to manually update the issue date of each sheet to match the latest revision date.
 Any suggestions would be awesome.
THANKS!!!
Mon, Nov 2, 2009 at 11:22:28 AM | Current Revision Date in sheet index
It will have to be a manual field.
Revision Schedules in Revit 2014
Mon, Feb 10, 2014 at 11:15:58 AM
Revision Schedule
Thu, Sep 13, 2007 at 2:13:38 AM
Revision editing
Wed, Sep 3, 2014 at 3:31:46 AM
2017- adding mutliple revisions to sheet index
Mon, Apr 15, 2019 at 3:29:19 PM
Revision date and number
Mon, Dec 29, 2008 at 4:59:58 PM
Page generation time: 0.7133
