15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Framing
Does anyone know how to keep the symbolic cutback for joists in coarse representation after dropping the beam to suit the under side of bering seat? I dropped my beams so that the joist seat are on the top of the flange but on plan I loose the cutback distance any help would be greatly appreciated, as I want to be able to cut sections form the model instead of drafting them out.
Welcome to the REvitlution!!! |
16 Posts No Rating |
When the stick line is uncooperative, unsophisticated REVITeers like me tend to make the line invisible and redraw with a "Detail Line" of the same lineweight as the stick line with the desired cutback. Caveat: this works okay but when we give these files to other disciplines on the team, all linework that was made invisible will show up.
Chuck George, George Structural Drafting, LLC - Orange, CA |
In the element properties dialogue box of the beam the joist is resting upon: 1. Change 'z-direction justification' to 'Other.' 2. Change 'z-direction offset value' to your joist seat depth. If it's 2 1/2" you will input a value of negative 2 1/2". Revit should still recognize these elements as joined. I'm guessing you were offseting the joist, but it is the beam which needs to be dropped. See attached image. Make sense?
Edited on: Mon, Nov 2, 2009 at 2:39:47 PM
Wood Framing Walls Extension; Locating and External framing |
Fri, Jul 31, 2015 at 8:03:14 PM
wood framing extension |
Mon, May 7, 2012 at 3:23:48 PM
Adding length parameter to framing tag |
Sun, Jul 18, 2010 at 4:19:26 PM
Framing Plan |
Tue, Jan 3, 2006 at 4:10:28 PM
12
What should the Revit Structure Cut Plane Depth be set to on framing sheets? |
Mon, Nov 21, 2011 at 1:44:28 PM
