Forums >> Revit Building >> Technical Support >> callouts and crop regions
Thu, Oct 29, 2009 at 8:24:26 AM | callouts and crop regions
saundevi
The project I'm working on is too big to fit on one sheet, so I used a matchline, and created duplicate dependent views, but I also have an area of the plan I want to enlarge that is split in two by the matchline. So I created a callout, but the crop regions cannot cut the callout graphic causing there to be this large half empty callout bubble on both of my dependent views. Why the heck can't the crop region cut the callout bubble?
Thu, Oct 29, 2009 at 8:31:28 AM | callouts and crop regions
I suggest you create your call-out from another view (maybe an overall that you keep it in or hide it) then use a callout in each half that uses the reference other view tool.
Crop Regions can't crop imported images
Mon, May 5, 2008 at 2:25:13 AM
Changing Lineweight of Crop Regions
Mon, Jun 19, 2017 at 8:39:07 AM
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Irregular Crop regions (Revit 2008)
Mon, Jan 28, 2008 at 12:00:04 PM
dimension text un-movable when crop regions applied to a wall section?
Wed, Feb 14, 2007 at 8:40:59 AM
Page generation time: 1.8225
