Forums >> Revit Building >> Technical Support >> Project file/folder relocation
Wed, Oct 28, 2009 at 4:35:33 PM | Project file/folder relocation
maranelloboy
3 Stars: 2 Votes
In my office, our projects move through in stages (separate folders on our server):  Prelim, Current, Construction Admin, and Archive.  The project file is kept in a folder structure in which we keep all of our project-custom materials, components, and so forth.  We have discovered how to relink most everything when we move a project into a different phase except for material image files, even when they're being moved with the rest of the project.  Is there any way to link these relatively, or are there any other work-arounds aside from keeping these custom material files in a static location?
Wed, Oct 28, 2009 at 5:00:38 PM | Project file/folder relocation
Why don't you copy everything to another folder and rename your current folder to the current phase.  In that way, you don't have to re-link anything....The other folders are really just frozen copies - right?  You will never really work with those but if you need to, you can adjust then.
Can revit to save to a primary backup folder instead of with the original file?
Wed, Dec 5, 2012 at 5:17:03 PM
Restoring Revit LT File
Tue, May 23, 2017 at 9:29:04 AM
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:43 AM
can you save backup files to a different folder? [ 1 2 3 ]
Wed, Sep 16, 2015 at 4:57:04 PM
39
Export to AutoCAD, folder structure
Wed, May 28, 2008 at 6:49:49 PM
Page generation time: 1.5956
