Forums >> Revit Building >> Technical Support >> help making a 2 top chord and 1 bottom chord joist.
Wed, Oct 28, 2009 at 11:55:23 AM | help making a 2 top chord and 1 bottom chord joist.
jdivina
Hi,
I need any tips or help making a joist that has 2 top chords and the webbing both slopes down to the middle where there is 1 bottom chord.
I am trying to make it using an existing joist and manipulating it. but I can't seem to make it work.
anyone?
JD
Wed, Oct 28, 2009 at 11:56:51 AM | help making a 2 top chord and 1 bottom chord joist.
jdivina
im using revit 2009
JD
Wed, Oct 28, 2009 at 12:07:55 PM | help making a 2 top chord and 1 bottom chord joist.
Get this pdf from the AutoDESK site "ArchitectureFamiliesImpENU"  - it explains how to set up families with angled elements that will flex correctly.
BTW - There is a lot of useful information on how to build families in this publication.
Edited on: Wed, Oct 28, 2009 at 12:34:18 PM
Wed, Oct 28, 2009 at 2:55:51 PM | help making a 2 top chord and 1 bottom chord joist.
jdivina
so ive been looking everywhere on that pdf.
is there a certain place i can look or mustv skipped.
i really just need help on why i cant rotate these elements.
does anyone know of a way i can do this with my problem.
JD
Wed, Oct 28, 2009 at 3:42:23 PM | help making a 2 top chord and 1 bottom chord joist.
tim123
4 Stars: 19 Votes
There's a little padlock icon if you click on the element.  Unlock it.
Wed, Oct 28, 2009 at 3:50:09 PM | help making a 2 top chord and 1 bottom chord joist.
jdivina
ive tried that.
i even ungrouped the arrayed objects.
it just doesnt want to rotate.
JD
Wed, Oct 28, 2009 at 4:15:56 PM | help making a 2 top chord and 1 bottom chord joist.
jdivina - read page 86....
Thu, Oct 29, 2009 at 10:09:20 AM | help making a 2 top chord and 1 bottom chord joist.
jdivina
thanks
ive tried that.
i guess its just a hard piece to do.
anyways thanks for the help
JD
Thu, Oct 29, 2009 at 10:13:10 AM | help making a 2 top chord and 1 bottom chord joist.
The reference line has to be placed first.  Can't place it afterwards.
Thu, Oct 29, 2009 at 10:20:03 AM | help making a 2 top chord and 1 bottom chord joist.
jdivina
i don't know what it is but it just seems like the angled webs won't rotate to that position. or to that reference line.
i think maybe im just doing it all wrong
JD
Thu, Oct 29, 2009 at 10:38:01 AM | help making a 2 top chord and 1 bottom chord joist.
As I said ... reference line has to be first.   Then create the shape along that line....
Single Pitch Top Chord Joist family?
Fri, Nov 30, 2012 at 7:49:29 AM
DLH Joist Bott. chord brg. sloped top chord
Mon, Dec 13, 2010 at 1:07:52 PM
DLH joist bottom chord bearing
Thu, Dec 9, 2010 at 8:40:09 PM
Joist Girder with sloping top chord
Mon, Sep 22, 2008 at 10:10:11 AM
Steel Joist- Top Chord Sloped
Fri, Dec 17, 2010 at 5:25:16 PM
Page generation time: 3.8049
