Forums >> Revit Building >> Technical Support >> Grid Line - Annotation
Tue, Oct 27, 2009 at 11:51:57 AM | Grid Line - Annotation
JOSIESEXTON
I am having trouble with my grid lines not showing on all of my plans.  I have tried everything I know and still they show on some and not on other for no apparent reason.  Does anyone have a suggestion or know what is going on
Tue, Oct 27, 2009 at 12:05:47 PM | Grid Line - Annotation
The gridlines have to extend through the rage of view to be seen.  Read this topic in your HELP "Datum Extents and Visibility"
Tue, Oct 27, 2009 at 12:38:48 PM | Grid Line - Annotation
JOSIESEXTON
That doesn't seem to be the problem.  The views are cut at the same level and the grids are turned on.  I even tried to see if it was an issue with the phasing, but nothing seems to work.  I have a call into a Support company, I'll let you know if they know how to fix the problem . . .Thanks for your responce!
Tue, Oct 27, 2009 at 1:18:53 PM | Grid Line - Annotation
JOSIESEXTON
WWhub-  I am not sure if this will make sense but . . . when making the building sections look graphically correct by pulling the bottom end of the grid line up so that they didn't intersect the section I did not change the small '3D' to '2D' before I pulled it up.  So . . . I guess I actually changed the extents of the grid line in three dimensions.  Does that make sense?  I figured it out before the support center called me back and it was hard to explain to them . . . . sorry, but thanks for your help!
Space between Grid Head and Grid Line not wanted!
Mon, Jan 28, 2013 at 4:14:54 PM
Curved/Arc Grid Line - NOT DASHED
Thu, Oct 13, 2011 at 11:22:19 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Grid Dimensioning
Tue, Jun 3, 2008 at 5:49:38 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:39 PM
Page generation time: 0.6557
