Forums >> Revit Building >> Technical Support >> cabinetry systems
Wed, Aug 24, 2005 at 3:41:11 PM | cabinetry systems
skr0013
I work for a design/build firm that also has a cabinetry shop. I want to use Revit to create cabinet family units that are easy to revise and modify. I also want to generate a cut list schedule for the shop. I was thinking that each piece (side panel, countertop, door) would be it's own family and they would all be nested together to create a cabinet unit family. I would then generate the components from that. I have seen the Woodwork Institute's cabinet components, and they are not parametrically detailed enough for what I want to do. If anyone has any experience or ideas on this matter please let me know.
Wed, Aug 24, 2005 at 6:03:39 PM | RE: cabinetry systems
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've found it sometimes works out well on small projects to model cabinetry as walls and floors... This allows you lots of freedom with scheduling and saves you creating families...
approaches to cabinetry?
Mon, Sep 5, 2005 at 6:26:39 PM
Crown Molding - Cabinetry
Wed, Jun 29, 2011 at 5:30:33 PM
Dealing with plumbing systems
Fri, Aug 31, 2012 at 5:27:33 PM
AWI Revit Cabinetry library
Mon, Dec 7, 2015 at 11:35:10 AM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Page generation time: 0.0428
