Forums >> Revit Building >> Technical Support >> External Image From Internal View
Fri, Oct 23, 2009 at 2:09:24 PM | External Image From Internal View
Altruant
Hi, i am fairly new to revit but have been trying to use an interior view looking outwards of a large curtain wall.
http://www.cadclips.com/Search.aspx then typed in 'background' - this then leads to the tutorial download
I have tried the CAD clip which requires downloading involving a putting the rendered image and a tif file then importing it over a jpeg background image. I have found that this only works with placing the building in a background and will not show the image through the windows.
Help would be very appreciated as this image is essential for my architectural project.
Kinds regards.
Fri, Oct 23, 2009 at 2:27:39 PM | External Image From Internal View
4 Stars: 205 Votes
Export the RENDER in a PNG file.
Fri, Oct 23, 2009 at 2:38:37 PM | External Image From Internal View
Altruant
Thanks so much mate - shoved it into photoshop and hey presto :D
Fri, Oct 23, 2009 at 2:58:44 PM | External Image From Internal View
Did you try it without glass in the windows?
Sat, Oct 24, 2009 at 6:55:59 AM | External Image From Internal View
Altruant
Removing the glass may have worked i'm not sure as i haven't tried but the PNG file and working in photoshop works great.
Thanks for the help though.
Sat, Oct 24, 2009 at 6:59:37 AM | External Image From Internal View
4 Stars: 205 Votes
Your Welcome...
Internal and External models
Wed, Nov 28, 2012 at 12:28:45 PM
L shape wall without removing top and base attachments
Tue, Jun 3, 2014 at 3:49:17 AM
Dividing an external wall into different parts per floor
Fri, May 12, 2017 at 3:46:57 PM
Help required with wall wrap at window & door jambs
Fri, Oct 16, 2015 at 4:57:19 AM
Internal Shadows in Plan view
Thu, Sep 14, 2006 at 1:17:38 AM
Page generation time: 1.9361
