Forums >> Revit Building >> Technical Support >> planter slope
Fri, Oct 23, 2009 at 11:05:47 AM | planter slope
jdivina
hi im using revit 2009.
and i am trying to make a planter with a bench attached to it. but here is my problem because i know that is not hard at all.  the ground is sloped. and i wanna keep the planter on the same slope as the ground. don't want to attach it because the the bench to the ground is longer. and i wanna maintain that 19" bench height.
this may be an easy answer.
but im just not to sure how to deal with this problem.
if anyone can help it would be greatly appreciated
thanks
JD
Fri, Oct 23, 2009 at 12:29:03 PM | planter slope
4 Stars: 205 Votes
If i understand right your problem just open the "planter" family, go to Setting>familie category and parameters and uncheck the "Always Vertical"
a planter
Mon, Jul 27, 2009 at 8:58:43 AM
Roof's wont slope :(
Mon, Apr 2, 2007 at 5:34:05 PM
Why does it say that my ramp has no slope when it does for a spot slope?
Thu, Jun 4, 2015 at 2:02:14 PM
Help slope tag showing wrong slope
Thu, Feb 27, 2014 at 8:21:23 PM
Stair stringer slope doesn't match riser slope?
Fri, Aug 21, 2015 at 10:30:14 AM
Page generation time: 0.7575
