Forums >> General Discussion >> Revit Project Management >> Create New Project from Old Project
Thu, Oct 22, 2009 at 3:21:10 PM | Create New Project from Old Project
minderoo
3 Stars: 2 Votes
Revit Architecture 2010
I'd like to know if there's a good process for starting a fresh project (no extra drafting views, unused families, project info, etc) using an existing model from an old project.  I want to bring in a building that we did remodel work to in a previous job, remove any demo objects, and make everything existing.  I tried linking in the model then binding it, but the demo objects from before come in as the same phase as everything else.
Thu, Oct 22, 2009 at 4:33:13 PM | Create New Project from Old Project
In  a copy of the old file, from a 3d view, show only items to be demoed.  Delete them.
Changing phases of objects can be tedious but here is a trick.  From settings / phases, change the name of existing to xxx.... then change the name of new construction to existing and then rename xxx to existing.  All items that were new are now existing.  You may have to adjust your graphic over-rides. Placeall new work in the new "new construction".
New Title Page Label Using Project Information
Sat, Feb 10, 2018 at 11:54:48 AM
Base Project template
Wed, Mar 22, 2006 at 10:09:57 PM
Create sub menu in Project Browser Floor Plan Views
Tue, Jan 1, 2013 at 8:34:40 PM
Mirror Project - Revit Architecture 2013
Sat, Jan 25, 2014 at 5:41:31 AM
Multiple Building Project. Need advice.
Tue, Oct 13, 2009 at 10:28:32 AM
Page generation time: 1.1090
