23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Parameter problem
Thu, Oct 22, 2009 at 8:01:33 AM | Parameter problem
geonv
Hi there. I have created a family into which I have loaded another family of a structural steel column. How is it possible to read the value of the parameter of the merged family ( that is the depth of the column), and place it to a new parameter in my main family?
Thu, Oct 22, 2009 at 9:00:55 AM | Parameter problem
The host family can drive the nested family but the nested can not drive the host.  You can read all about nested families in your HELP.
Thu, Oct 22, 2009 at 10:14:18 AM | Parameter problem
Bronsart
Basically, you have to create parameters in your host family ("column height" for example).  Then go into the properties of your nested family and link the nested parameters with the parameters of the host family.  There should be some good videos on the specifics of nested families.  I suggest you get a good handle of the nested families because they are very useful.
Mike
Parameter names with dashes - problem with formula
Tue, Aug 31, 2010 at 10:28:39 AM
3D Swing parameter!! Help!!
Sat, May 11, 2013 at 7:03:34 AM
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Loadable Family Parameter Problem
Mon, Jan 16, 2006 at 5:49:28 PM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Page generation time: 1.7456
