16 Users Online (14 Members):
Forums >> Revit Building >> Tips & Tricks >> Loat in Revit - 18 places to look and a few things to try before you lose it
Lost in Revit Its gone. Here are 18 places to look. Basics - Visibility graphics – Is the category on (V V)
- Are you zoomed in or out too far? Zoom all – (ZE or ZF)
- Is it hidden in the view – Use the lightbulb on the bottom toolbar
- Is it temporarily hidden – Look for cyan border on screen. Use glasses on bottom toolbar
- Is the workset on?
- Is it in the right workset – Note copying an item will put it in the current workset not the same workset as the original.
- Is the workset turned off in the view (V V)
- Is it outside the crop region – show crop region to check – blue icon on bottom toolbar
- Is the view depth setting set up to show it. (VP)
- Was it inserted on a level different from what you expected
- Is the detail level setting ok – Square icon on bottom toolbar
- Is the phase set correctly? May be in a different phase – Existing demo or new construction (VP)
- Are the phase filters set up correctly (VP)
- Were invisible lines used eg in a filled region
- Is it a mass with the mass category turned off – Icon on top toolbar beside 3D house icon
- If a pasted detail object is mostly outside the view crop region it will not be visible. Turn off crop.
- It might be excluded from a group instance (will show up when you hover over the group) Select the group and right click to restore all excluded
- Grids, Levels missing – are they associated with a scope box that is not intersected by the view
- Sections and elevation markers - 'hide at scales coarser than'. (tim123)
Some things to try Create a new 3D view so there are no visibility setting adjusted. Try a section box to look at slices Use wireframe setting on bottom toolbar Temporarily turn off items or categories to see if it is hidden Turn on all worksets What have I missed? Matt Cantwell Edited on: Wed, Oct 21, 2009 at 5:33:07 AMEdited on: Wed, Oct 21, 2009 at 5:33:43 AM
Edited on: Tue, Nov 24, 2009 at 3:22:45 AM
What do I lose if I use a floor family to model a flat roof? |
Mon, Aug 13, 2012 at 10:59:19 AM
Elements can't be copied because they will lose their References. |
Wed, May 13, 2015 at 4:43:24 PM
Selecting Things I Can't see |
Fri, Jun 5, 2015 at 9:34:18 AM
facade_curved wall |
Thu, May 1, 2014 at 1:02:13 PM
high windows in plan? |
Thu, Apr 27, 2006 at 8:30:11 AM
