Forums >> Revit Building >> Technical Support >> Wall Hosted Cut Wall Line Weights
Mon, Oct 19, 2009 at 9:16:41 AM | Wall Hosted Cut Wall Line Weights
JDAGEN
I know I saw this somewhere before but cannot find it now. Hopefully someone can help. Our walls in plan veiw cut at a heavy line weight. However wherever we have wall hosted casework or specialty equipment the thinner line weight of the component overrides the thick line weight of the cut wall. I know changing the transparency in visibility graphics corrects the problem, but it also makes the casework completley transparent (wire frame). does any one know of another work around?
- Thanks.
Mon, Oct 19, 2009 at 2:30:05 PM | Wall Hosted Cut Wall Line Weights
tim123
4 Stars: 19 Votes
You should be able to use the linework tool to do it.
Tue, Oct 20, 2009 at 8:13:34 PM | Wall Hosted Cut Wall Line Weights
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Also, in your visual graphics, every objest has a "cut projection" for all subcatagories with the object. This is where you can set the line wait for that object when cut in section.
J. Allen Ball
Line weights & detailing 2012
Thu, Jun 6, 2013 at 7:51:24 PM
Automatic Line Weights
Wed, Mar 31, 2010 at 6:30:48 AM
Cut Profile Line Weights (Revit Glitch?)
Tue, Aug 22, 2017 at 4:23:29 PM
Wishlist - Multiple cut weights to walls
Sat, Jan 8, 2011 at 10:48:15 PM
Wall hosted familes cutting through 2 types of walls
Thu, Oct 27, 2011 at 10:42:15 AM
Page generation time: 0.8693
