Forums >> Community >> Newbies >> Changing the line weight of objects in distance.
Thu, Oct 15, 2009 at 2:22:08 PM | Changing the line weight of objects in distance.
nathanp
Hi
I'm tryingto work out how to change the line weights of objects in the distance. I am doing a section through one building and i can see another building behind it. I want to make the building behind lighter than the building I have the section going through. I have tried making everything half tone however this is to light. Is there a way to get all objects between half tone and the normal line weight. I am using Revit Arch 2009. Thanks
Fri, Oct 16, 2009 at 11:55:15 AM | Changing the line weight of objects in distance.
If it is a linked model, you can shade it.  You can also do tghat by selecting all of it and over-riding graphics in view.
Fri, Oct 16, 2009 at 1:01:49 PM | Changing the line weight of objects in distance.
coreed
coreed Avatar
4 Stars: 16 Votes
have a look at this. it may help
http://blog.cadway.com.au/2009/04/revit-elevationsection-view-depth.html
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
changing property line weight in Revit 2009
Thu, Jun 18, 2009 at 12:58:52 PM
Elevations line weight
Mon, Feb 4, 2008 at 9:03:42 AM
Changing line weights to hatching?
Wed, Apr 26, 2006 at 10:44:00 PM
Changing line patterns and weight below the ground line
Mon, Apr 29, 2013 at 7:24:23 AM
Changing line weight of callout bubbles?
Thu, Sep 21, 2006 at 2:38:28 PM
Page generation time: 2.2971
