Forums >> Revit Building >> Technical Support >> Sketchup to Revit - Layer/Material Problems
Thu, Oct 15, 2009 at 12:10:40 PM | Sketchup to Revit - Layer/Material Problems
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
I'm having an annoying (and apparently common) problem when importing a sketchup file in to revit. I cannot get more than one material to apply to an imported sketchup object! I set one material per layer to the object when still in sketchup, but when I import it into Revit and query the various surfaces, everying is reverted to the "default" layer. I can apply a material to the "default" layer in the object styles menu, but since all surfaces are locked to that layer I can't change any surfaces independently of that! Super frustrating, any advice?
using revit 2010
Thu, Oct 15, 2009 at 12:17:45 PM | Sketchup to Revit - Layer/Material Problems
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Go to Settings-->Materials....and there you can change all the materials you want, and as an advice, change their names i.e. Render Material ### to whatever other name you want....
Thu, Oct 15, 2009 at 1:24:15 PM | erland73
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Quoting erland73 from 2009-10-15 12:17:45
"Go to Settings-->Materials....and there you can change all the materials you want, and as an advice, change their names i.e. Render Material ### to whatever other name you want...."
I've done this numerous times to no avail. The problem is the fact that those colors ( i.e. render material xxx-xxx) are associated with each imported layer in the object from sketchup. For some reason, when the import occurs, all planes in the object are shifted to the "default" layer of the object. All other layers become empty, which means the colors (render material xx-xxx) associated with them affect nothing in the imported object. erland,  I've read your response to a previous posting of the same question. I'm not sure if you've tried what your saying but it simply does not work for objects imported directly from sketchup into revit. Any other possibilities to what might cause this?
Thu, Oct 15, 2009 at 1:25:53 PM | Sketchup to Revit - Layer/Material Problems
4 Stars: 205 Votes
Well, export the model to DWG, import the model in REVIT and check...
Thu, Oct 15, 2009 at 1:30:31 PM | erland73
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Thu, Oct 15, 2009 at 1:34:09 PM | Sketchup to Revit - Layer/Material Problems
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Well since I'm not using Sketchup Pro I don't belive I can export to DWG. I'm speaking of a direct import from SketchUp to Revit. This shouldn't be complicated, but it seems like theres very few who know how...
Thu, Oct 15, 2009 at 1:39:41 PM | Sketchup to Revit - Layer/Material Problems
4 Stars: 205 Votes
Put here the model to download.
Thu, Oct 15, 2009 at 1:49:47 PM | Sketchup to Revit - Layer/Material Problems
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Unfortunately, I have about 10 fixtures from sketchup, so it might not be practicle for you to convert all of them into DWGs, but this will be a worth while experiment. I'm not doubting that the imported layers will work from a DWG; that seems to be the general concensus on RC. What I haven't seen is any good explenation of how to keep layers alive from a direct sketchup to revit import. Thanks very much for the help guys, I appreciate it.
Thu, Oct 15, 2009 at 2:05:54 PM | Sketchup to Revit - Layer/Material Problems
4 Stars: 205 Votes
You have ONLY ONE "material/color" in that object, that's why....
Also, it's so easy to create this in Revit, why don't you do that?
Edited on: Thu, Oct 15, 2009 at 2:10:17 PM
Thu, Oct 15, 2009 at 2:17:39 PM | Sketchup to Revit - Layer/Material Problems
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
sorry wrong file. that one is old and unmodified. here's an updated fixture, with multiple layer/render colors. go ahead and try the query tool in revit and you tool will see that all planes have been shifted to the "default" layer, despite being seperated when in sketchup.
Thu, Oct 15, 2009 at 2:19:46 PM | Sketchup to Revit - Layer/Material Problems
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
And BTW, these fixtures were given to me for use in several projects, and I didn't plan on reconstructing 120 of them in Revit. Thats why...
Thu, Oct 15, 2009 at 2:30:28 PM | Sketchup to Revit - Layer/Material Problems
4 Stars: 205 Votes
Like you can see, there are two "Render ####" material in that model, so now i can change them...
Also if you search in the forum you will find lots of thread like this one in the past:  http://www.revitcity.com/forums.php?action=viewthread&thread_id=15792
Edited on: Thu, Oct 15, 2009 at 2:33:27 PM
Thu, Oct 15, 2009 at 2:48:21 PM | Typhoon
#13
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
did you export the file as a dwg before you brough it in to revit? if you did, how do you accomplish this via a straight import from sketchup to revit?
Thu, Oct 15, 2009 at 3:04:34 PM | Typhoon
#14
cadviz
Quoting Typhoon from 2009-10-15 14:05:54
Edited on: Thu, Oct 15, 2009 at 2:10:17 PM"
maybe he hates modeling in revit like i do. lol i would do it in AutoCAD and import it to Revit Winking
If plans & specs don't match, it equals a shitty project.
CADVIZ
Thu, Oct 15, 2009 at 3:04:50 PM | Sketchup to Revit - Layer/Material Problems
#15
4 Stars: 205 Votes
"did you export the file as a dwg before you brough it in to revit?" - YES
 about the second question check the HELP menu, i think this anwser your question... That's why i ALWAYS import the model to CAD to "arrange" the model because i don't know how it is...
again:  "if you search in the forum you will find lots of thread like this one"
Edited on: Thu, Oct 15, 2009 at 3:16:19 PM
Need Help - Sketchup To Revit Layers
Thu, Oct 15, 2009 at 11:37:08 AM
Sketchup To Revit Problems *Please Help*
Thu, Mar 12, 2009 at 9:21:29 AM
Sketchup to Revit material problem [ 1 2 ]
Wed, Jun 30, 2010 at 11:58:37 AM
26
PLEASE HELP! Revit + Sketchup intol Artlantis
Sat, Jun 7, 2014 at 6:26:28 AM
13
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Page generation time: 5.7035
