25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Wall Edit Assembly- material thickness uneditable
160 Posts No Rating |
using a wall type that I believe came with the standard template revit arch 2010 stud wall with two finish materials one above the other each finish material has a defined thickness and surface pattern the thickness option is greyed out and I can't change it. Is there a chance it could be defined somewhere in the materials. also, changing the surface pattern and checking the model radio button has no effect on the model. What am I missing? thanks for any input
it looks like you are talking about stacked walls, it is a wall that is made up of 2 different walls, just get the name of your wall from the stacked wall properties and change the properties of these indevidual walls. is it clear?
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
wall type properties?? |
Mon, Jul 28, 2008 at 9:47:23 AM
Modifying vertical structure in edit assembly |
Fri, Feb 9, 2018 at 4:27:20 PM
assembly |
Mon, Apr 22, 2013 at 5:03:46 AM
Changing the Material [...] in Edit Assembly isn't bringing up Materials Palette |
Fri, Mar 28, 2014 at 4:12:50 PM
